Audioposimine
    Vs: Audioposimine
    Võibolla toodetakse seda värki vanadest saabastest siis...
      Vs: Audioposimine
      Kuldkingad on siiani kuulsad ... laste lugemisvaras!
        Vs: Audioposimine
        Ise kasutan vahest sellist digikaablit:
        Stein Music ONYX DX-3002 featuring Digital SPDIF Cable and Re-clocking Box Combination: Retail $2695
        This digital cable plus major league re-clocking jitter reduction box is no small affair. The box is rather large with built-in cables on each side. The whole thing is impressive, and the power comes from a slick external adapter with on/off switch. It looks important and it is! Sounding somewhere between the Kubala-Sosna Elation! digital cable and the Jorma Digital Cable, it has a presentation that is dramatic, powerful, and super solid. Placed between an Esoteric 03 transport and the E.A.R. DACute, it was most exciting, clear, and realistic.
        As we changed power cords to the Esoteric, the Onyx changed, too. It is a revealing piece, and hard to maximize as a result. It is also bulky and tough to maneuver. That said, I liked it for its limitless transparency and textural rightness. The tape-like solidity of the sound is also very fetching. I’m not sure it is that much better than a top-of-the-line digital cable alone, but more experimentation is needed. Right now I would give the Onyx a conditional, but positive, recommendation.
          Kui juba on kasutusel pesumasin Whirlpool, kas ka siis on sellest seadmest abi? Võiks ju plaadid paigaldada Whirlpooli peale, või alla ja need puhastuvad pöörisvooludest? Kas mõttekäik võiks olla toimiv? Pesumasin on ju veel suurem kui see seade, võiks ju olla siis ka tõhusam?
          Click image for larger version  Name:	whirlpool.jpg Views:	0 Size:	238,7 KB ID:	1107846
            Alati on selgunud, et "päeva lõpuks" on need kaablid ikka vaid juhtmed.
            https://www.youtube.com/watch?v=2EWPRgu2YNw
              Palju siis maksis selline nali?
                Miks peaks sõnatuks võtma?
                Väidetavalt ( https://en.wikipedia.org/wiki/List_o...us_populations )
                on "mitteuskujaid" ainult ~15%. Vot see võtab sõnatuks aastal 2020.
                  Kuidagi sobib tänase maailmaga, kus maakera on lapik, matemaatikuks saamiseks peab teadma et 2x2=5, füüsikaseadused on asendatud mitmekesiste uskumustega. Peaks võtma ka Mangilt veel kommentaari...
                    Mulle NII VÄGA meeldib : “ Teaduslikult on tõestatud, et inimesed usuvad mida on teaduslikult tõestatud “ !!!
                    GU50, Sinu viimane postitus ei ole “ teaduslikult tõestatud “ :-)
                      Väga kõva masin, peaks vist soetama! Kirjeldus on igatahes paljulubav -For signal between the preamplifier and power amplifier, it could reach as high as 10 volt. If the input impedance of the power amplifier is 4.7 KW, the power calculated would be at about 20 mW. In that case, QBT is 250 times stronger than normal signal strength.
                      Huvitav, kas meil Eestis sellega teenust müüa õnnestuks? Kaablid pakikulleriga kohale ja siis nädala pärast tagasi aga juba oluliselt parematena...? Teenustasu võiks olla äkki miskit 99.- per kaabel?
                      Masin ise selline: https://telos-audio.com.tw/qbt-cable...zZP8viAM1J93LM
