Kammfiltri efekt
Vs: Kammfiltri efekt
Kui keegi tunneb AudioMulch tarkvara ehk viskab pilgu peale, kas pildil olev DSP laadne toode annab kokku selle RACE algoritmi. Mul on väike kahtlus et seal ei liigu kanalite vahel pööratud faasiga signaal (seda teeb see PingPong1 funktsioon) päris õigest. Wet/dry seadistus on 100% ja Feedback on 75%
Appendix: AcousticsDynaudio Professional AIR reference manual – 2014-08-28115Dip frequenciesCancellation occurs for a comb filter at all the frequen-cies where the two signals are in opposite phase. This occurs when the time delay comprises duration of 0.5, 1.5, 2.5 etc. periods. At 1 kHz, the period is 1 millisec-ond. Half of the period is 0.5 milliseconds.If a time delay of precisely 0.5 millisecond occurs, this will result in cancellation not only at 1 kHz, but also at 2 kHz, 3 kHz, 4 kHz etc
lk.115
Ilmselt provotseerib audiofiilia aja jooksul retrofiilse modernofoobia arengut.Comment
