Paistab, et mingi suurem jama neil?
Yahoo surnud?
Sildid: Puudub
Vs: Yahoo surnud?
Töötab-töötab. Või mida see "minul mitte" täpsemalt tähendab?
Võtad http://nmap.org/download.html + http://www.winpcap.org/install/default.htm ja siis selles sitikmustas aknas annad käsu...
nping --tr --tcp -p 443 yahoo.com
Kaugele päring läheb?
Kood:[B]SENT[/B] (0.2810s) TCP 192.168.1.65:25807 > [B]206.190.36.45:443[/B] S ttl=1 RCVD (0.3590s) ICMP [192.168.1.254 > 192.168.1.65 TTL=0 during transit SENT (1.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=2 RCVD (1.3440s) ICMP [90.190.184.2 > 192.168.1.65 TTL=0 during transit SENT (2.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=3 RCVD (2.3280s) ICMP [90.190.134.112 > 192.168.1.65 TTL=0 during transit SENT (3.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=4 RCVD (3.3590s) ICMP [194.126.123.8 > 192.168.1.65 TTL=0 during transit SENT (4.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=5 RCVD (4.3750s) ICMP [194.126.123.62 > 192.168.1.65 TTL=0 during transit SENT (5.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=6 RCVD (5.4060s) ICMP [195.66.224.129 > 192.168.1.65 TTL=0 during transit SENT (6.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=7 RCVD (6.4380s) ICMP [66.196.65.13 > 192.168.1.65 TTL=0 during transit SENT (7.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=8 RCVD (7.4380s) ICMP [216.115.100.92 > 192.168.1.65 TTL=0 during transit SENT (8.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=9 RCVD (8.4840s) ICMP [216.115.101.145 > 192.168.1.65 TTL=0 during transit SENT (9.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=10 RCVD (9.5310s) ICMP [216.115.96.121 > 192.168.1.65 TTL=0 during transit SENT (10.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=11 RCVD (10.5160s) ICMP [216.115.96.122 > 192.168.1.65 TTL=0 during transit SENT (11.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=12 RCVD (11.5160s) ICMP [66.196.67.5 > 192.168.1.65 TTL=0 during transit SENT (12.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=13 RCVD (12.5160s) ICMP [98.137.31.135 > 192.168.1.65 TTL=0 during transit SENT (13.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=14 RCVD (13.5160s) ICMP [98.137.31.184 > 192.168.1.65 TTL=0 during transit SENT (14.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=15 RCVD (14.5160s) ICMP [206.190.32.23 > 192.168.1.65 TTL=0 during transit SENT (15.2970s) TCP 192.168.1.65:25807 > 206.190.36.45:443 S ttl=16 [B]RCVD[/B] (15.5160s) TCP [B]206.190.36.45:443[/B] > 192.168.1.65:25807 [B]SA[/B] ttl=110
Vs: Yahoo surnud?
http://www.downforeveryoneorjustme.com on väga hea koht sellise probleemi uurimise alustamiseks.Comment
Vs: Yahoo surnud?
Kui otse kirjutada siis on Yahoo olemas aga
Firefoxi otsijate aknasse teda ei saa.
Aga ega ta paremini ei otsi kui need teised.
Kunagi oli tark AltaVista aga nüüd tuleb selle asemele Yahoo.
Lobisevad kõik nagu jõuavad selle asemel et aidata leida.Comment
Vs: Yahoo surnud?
No aga proovi siis.
(Sinna aknasse tuleb domeeninimi kirjutada, nt elfafoorum.eu, ja kui sait on serveris või suure välisühenduse tagant maas, siis saab ka vastava teate ega pea oma arvutit kahtlustama.)Comment
Vs: Yahoo surnud?
Seda, et Sinu arvutis Yahoo tegelikult avaneb, see kontrollileht ju ei tea. See kontrollib vaid seda, kas sait on serveris üleval või maas, muud midagi. Kas Yahoo Sinu arvutis avaneb või ei avane, näeb kasutaja ise ning teeb sellest (loogilise) järelduse.Comment
Vs: Yahoo surnud?
Mis vahet on sellega kui nimi on tavaaknas?
JavaScripis otsing ei ole targem.
It's just you. http://altavista.com is up. on VALE väide
Valetamine on ka see et Yahoo on oma nime sokutanud tunduvalt asjalikuma otsingumootori asemele.
Kas müüdi või vahetati aga otsing on nüüd hulga viletsam.Comment
Vs: Yahoo surnud?
Siin lisaks muude suletavate teenuste andmed.Comment
Vs: Yahoo surnud?
Kui saia asemel sõnnikut pakkuda siis oled sa kalorid kätte saanud.
Seega tehniliselt võttes oled söönud.
AltaVista oli tehniliselt arenenud otsingumootor.
Selles ongi kurbloolisus.
_________________________
Aga kui kasutada neid "mootoreid, ka foorumi oma" eelotsinguks?
Lasta kõik saadu salvestada ja siis teha sealt täpisotsing.
Seda on igaühel võimalik kirjutada oma arvutis ja
saad täpselt see mida tahad.Comment
