Dell D830
  • apheks
    • 182
    Vs: Dell D830
    Mõne delli korral on aidanud biosi üle kirjutamine, aga kas d830 ka selle alla käib, ei julge lubada. Hangid odava spi programmaatori ja saad teada.
    • saformo
      • 03/2003
      • 1929
      Vs: Dell D830
      Leidsin pisut infot, ehk on kasu ...
      Dell BIOS-i taastamine, vaata ka: http://www.bay-wolf.com/bootcd-bios.htm
      How to recover from a bad BIOS Flash (Phoenix BIOS ONLY)
      Alienware M17XR2 Crisis Recovery Procedure
      1. Download the latest dell bios A10 from website and extract content onto desktop.
      2. Locate crisis.zip file and copy onto memory stick
      3. Insert usb memory stick onto windows xp computer only. And extract contents of crisis.zip onto desktop.
      4. There should be 7 files on the desktop, run wincris file (floppy disk icon).
      5. A dialogue box will appear, under the driver tab select your usb drive.
      6. Press start and confirm ok to continue. This will copy all files to the usb stick, and then safely remove usb drive.
      7. Shut down your Alienware, insert your usb key into the esata port (left side).
      8. Remove battery, ac adapter and perform power drain.
      9. Press down keys FN and B together, while keeping depressed press and keep down the power on button for three seconds, then let go keeping the FN and B buttons still pressed.
      10. The usb drive will flash briefly then pause and then will flash continuously for 30 seconds, the lcd display will remain blank. AT THIS POINT DO NOT TURN OF THE COMPUTER.
      11. After 5 mins approx the computer will automatically shut down and reboot hopefully recovering your computer back from a bad bios flash.
      IMPORTANT! THE USB RECOVERY STICK CAN ONLY BE CREATED BY USING WINDOWS XP.
      • saamuel
        • 04/2014
        • 53
        Vs: Dell D830
        See õpetus käib arvuti kohta, mille bios-ile ja win-ile saab ligi. Minu arvutil on käivitades kohe ees kiri, et on vaja sisestada parool. Sellest edasi ei saa kuhugi kui parooli ei tea.
        • apheks
          • 182
          Vs: Dell D830
          Recovery-ga annab taastada masinaid mis ei reageeri tavaolukorras ka power nupule enam. Samas pole kindel kas recoveryga ka paroolist lahti saab, see võib jätta teatavad regioonid kirjutamata. Kus kandis masin asub, kui Tallinnas, siis saan biosi üle kirjutada 10 euriga, kui plaadi ise korpusest välja võtad. Saada PS kui huvi on.
          • saamuel
            • 04/2014
            • 53
            Vs: Dell D830
            Meie kirjavahetuse jätkuks Delli esinduse hind langes täna 15%. Näis mis edasi saab. Kohe huvitav jälgida.
            • haanjamiis
              • 09/2004
              • 99
              Vs: Dell D830
              33aq47t9
              MM0MhzG1gdVH30S2
              835rvp4h
              83i99ons
              y0gj0e73
              d2hr9csy
              Äkki need
              viimati muutis kasutaja haanjamiis; 15 December 2014, 13:44.
              haanjamiis vidi lubjakivve...
              • tcumen
                • 10/2005
                • 2077
                Vs: Dell D830
                Kas oled proovinud infot otsida ka emaplaadi mudeli järgi? Kusagil plaadil peaks see olema, mõnel tootjal kleepsuna, mõnel trükituna.
                Vahel võib nii üllatavaid tulemusi saada.
                • mesimees
                  • 02/2009
                  • 10
                  Vs: Dell D830
                  Sportlikust huvist küsin, et kas see oksjon:
                  Vaatasin seda kah, aga kuna mul ainult mõnesid korpuse liiste vaja, pidasin paljuks tervet arvutit ära osta.
                  Mul kah paar poolkomplektset d830 arvutit, võiks ehk juppide osas miskit koostööd teha.
                  Mart 55906733
                  • saamuel
                    • 04/2014
                    • 53
                    Vs: Dell D830
                    Ei ole see oksjon. Mina ostsin osta.ee-st. Muide seal müüdi RMK D830 25tk korraga maha. Olen jälginud müügiportaale aga suurt D830 müügipakkumise tõusu pole märgata, ju siis müüakse vast ebay-s või kuskil mujal väljapoole Eestit.
