Soovitage head lampvõimendit
    • 7723
    #76
    Vs: Soovitage head lampvõimendit
    Kellele kuidas. Stereophile arvas näiteks nii ja see viitab just kõrgetele THD ja IMD numbritele:
    Unfortunately, there was also an unremitting hardness in the upper midrange and top end, even at moderate SPLs, that was downright fatiguing to me and to visitors. Nor did it take experienced listeners long to pick up on it. It didn't sound like grain, and it certainly didn't sound like glare. Instead, it was an opaque wall against which high-frequency transients struck and stuck. It created that sensation of hardness while preventing the creation of delicacy and dimensionality—and, especially, natural decay in the upper octaves.
    • Sonic
      • 02/2004
      • 1144
      #77
      Kuidas kommenteerite selliseid võimendi parameetreid?
      Specifications:
      Output power W rms 8/4/2 ohm: 100/200/400
      Gain: 26 dB
      Input sensitivity: 1.41 Vrms
      Frequency response: (1W rms -3dB) 0,3 Hz ÷ 1 MHzSlew-Rate (on 8 ohm): > 200 V/?S
      THD: < 0,05 %
      S/N Ratio: 108 dB
      Input impedance Unbalanced: 24, 28, 42, 57 Kohm Balanced:23 Kohm
      Damping factor: (on 8 ohm) 85
      Main voltage AC (50-60Hz): 100, 110-115, 220-230, 240 V
      Power consumption: 500 W, 1400 W MAX
      Dimensions and weigth: 470w x 245H x 540D mm - 52 Kg
      Shipping dimensions and weigth: 540w x 400H x 620D mm - 60 Kg
        • 7723
        #78
        Kas see on lampvõim?
        Tegelikult, kui sa midagi müüd, pane kohe korralik info koos nime ja hinnaga, milleks selline kassi-hiire mäng?
        • Starfish
          • 08/2009
          • 2294
          #79
          1.41V*(+26dB)=28.13V
          28.13^2/8=98.9W
          28.13^2/4=197.8W
          28.13^2/2=395.6W
          Gain: 26 dB
          2.82V (8Ω)-3dB=1.9V
          On see elektroonikalabori võimendi ?
          Mida on teha 0,3Hz kuni 1MHz helitehnikas?
          Ma saaks aru kui riba on lahtine kuni 30kHz kui on riba piiramiseks kasutusel lihtne filter, millel sumbumine hakkab kaugelt.
          Pole garantiid et see tõene on, pigem on see müügitrikk.
          200Vus ?
          Max võimsusel jääb väheks seda 1MHz jaoks
          • Sonic
            • 02/2004
            • 1144
            #80
            Esmalt postitatud moi poolt
            See ei ole lampvõim ja ma ei taha seda müüa. Pigem ehk osta.
              • 7723
              #81
              200Vus ?
              Sul need arvutused käpas, milline ülemine -3dB sagedus tuleb maksimum võimsusel selle 200 V/µS kasvukiirusega?
              Ma natuke saan aru sellest ülemisest piirsagedusest (sellest ka suht suur kasvukiirus), see võimaldab suure võimsuse juures saada korralikku impulsskarakteristikut, ehk kui on vaja eriti tuimasid kõlareid kaugelt kuulata ei teki moonutusi.
              Võim ise on "AUDIA FLIGHT Classic FL100 class A 100w Stereo power amp"
              Tegelikult oleks huvitav teada kuidas nad A-klassis alaliskomponendi blokeerisid nii, et 0,3 Hz -3db said.
              • Starfish
                • 08/2009
                • 2294
                #82
                Robustne arvutus annab 800kHz (Tõusukiirusega 200V/us, väljundpingega 28V).
                Tegelt eks see pinge on madalam, 800k on kindlasti languse ala sees.
                  • 7723
                  #83
                  See on ju väga hea number, isegi kui 400 kHz oleks täisvõimsusel ülemine -3 dB punkt, oleks ka väga hea number.
                  • Sonic
                    • 02/2004
                    • 1144
                    #84
                    Kui keegi viitsib pilgu peale heita Audia eelvõimule, siis millised on järeldused? Kas korralik või pigem kehvapoolne?
                    Laadige endale alla hifiengine lehelt.
                    viimati muutis kasutaja Scott; 09 November 2018, 07:57. Põhjus: korrastus
                      • 7723
                      #85
                      Esmalt postitatud Sonic poolt
                      Võime üldiselt kuulatakse, mitte ei vaadata .
                      Kui siiski vaadata pilte sisust, siis mikroskeemide, releede, toite kondede ja raha poolelt pole kokku hoitud, kuigi teksti järgi peaks võimendusaste olema diskreetsetel elementidel ja A-klassis.
                      Osta ära.
                      • Sonic
                        • 02/2004
                        • 1144
                        #86
                        Osta ära.
                        Kas see on irooniaga öeldud?
                          • 7723
                          #87
                          On seal vahet?
                          Nagunii ilma ostmata ei saa teada, mis ta tegelikult on.
                          Piltide ja paberi järgi võib arvata mida iganes, kellel kui kõrge lennuga fantaasia on.
                          Seda sa ilmselt tead isegi kui raske tast lahti on saada meil sama hinnaga, millega ta väljamaal müügis on, nii et ikka otsustad ise oma äranägemise järgi.
                          • Sonic
                            • 02/2004
                            • 1144
                            #88
                            Kas kuulama tuled, kui ära ostan?
Name:	Audia Flight Pre MK1.jpg
Name:	Audia Flight Pre MK3.jpg
                            Kas on ka mingit olulist vahet MK1 ja MK3 vahel?
                            viimati muutis kasutaja Scott; 09 November 2018, 07:55. Põhjus: järjestikpostitused kokku
                              • 7723
                              #89
                              Erinevusi on aga pildid on liiga pisikesed. Kuulama võiks tulla aga Valga ei jää kuidagi tee peale.
                              • rein113
                                • 07/2004
                                • 229
                                #90
                                Moi, mäletan juhtumit Thorens 302-ga, kus paljudel oli kohe, nähes pilte sisust, oma arvamus selle seadme olemusest, hinnast ja kvaliteedist. Võiks ju nüüd ka?
