Kolm kõrgsageduse valjukat ühes kõlaris
  • hipster
    • 04/2020
    • 111
    Kas selline kombinatsioon teoorias võiks toimida?
    Kolmeribalised kõlarid, esimest järku filtritega näiteks, ring radiatorid ja isodünaamilised lõigata kusagil 7kHz-i kandis.
    This page has been removed, but Madisound has thousands of loudspeaker parts. Contact us today at info@madisound.com.
    RT1C-A Isodynamic Tweeter, 120mm, 94dBFrequency range 4.5k to 23kHzThe key element of the RT1C-A is the membrane, which consists of Kapton film with a pattern of Aluminum conductors. The conductors cover about 90% of the whole vibrating area. The membrane assembly is placed precisely between two rows of Neodymium bar magnets. An aluminum mounting flange, with flared wave-guide, controls the frequency response and directivity of the tweeter. The clamped membrane area is connected to the front metal plate. This, combined with a special heat conductive compound, provides effective cooling of the aluminum conductors. This tweeter is magnetically shielded and is an extremely flat driver. Its depth is only 18 mm including the mounting flange.The RT1C-A has resistive impedance in the audio frequency range. This unique feature provides a friendly load for any amplifier and facilitates easy crossover design. Unlike other drivers, the RT1C-A has an essentially linear phase response that provides time coherent reproduction resulting in accurate musical rhythm and imaging. The vibrating element of the RT1C-A is almost weightless compared to that of a dome tweeter. As a result it provides an immediate and precise response to any transients in the original signal. The RT1C-A has an exceptional ability to reveal the dynamics of instruments with complex high frequency spectra.Unlike conventional tweeters and electrostatic speakers, the RT1C-A has an extremely wide sound dispersion in the horizontal plane. The radiating area of the tweeter is 50 x 13 mm, where 13 mm defines the horizontal dimension. At the same time, contrary to other dynamic tweeters, the RT1C-A has well-controlled dispersion in the vertical plane. This feature helps to avoid disturbing floor and ceiling reflections, increasing imaging accuracy. With this tweeter there is no need to manipulate the network or use multiple units to achieve the restricted vertical directivity necessary for home theater applications.When considering all of the properties of the RT1C-A, it becomes clear why many critical listeners among audiophiles highly prize planar transducers. They possess unsurpassed clarity, transparency and the ability to deliver every tiniest musical detail.Since the RT1C-A has exceptional ability to reveal the dynamics of instruments and sonic resolution, it is recommended to match it with drivers having similar properties in order to maximize the overall integrity of a speaker system. Nominal Impedance (Z)(Ω) : 5 ohms Nominal Power Handling (Pnom)(W) : 15 Sensitivity (2.83v/1m)(dB) : 94 Weight (M)(Kg): 0.2 Magnet System : Neodymium Rec. Crossover Frequency(Hz) : >4500HzMagnet dimensions.Width 74.5mm (width of raised part of magnet 54.5mm)Height 89.5mmDepth from back of flange to back of screws, no gasket, 12.5mmTweeter ribbon opening is 52mm x 9.5mm with a divider.
    • 7723
    Vs: Kolm kõrgsageduse valjukat ühes kõlaris
    Kui sa filtritega AKS täpselt ühes ruumipunktis sirgeks ajad, siis seal ruumipunktis toimivad, natukene kõrgemal või madalamal ka toimivad aga augud tekkivad ASK-sse tänu faasinihetest tekkivale kammfiltrile.
    viimati muutis kasutaja moi; 24 April 2020, 21:39.
    • OSX
      • 02/2007
      • 5594
      Toimib praktikas ka, mitte ainult teoorias. Kõrged on huvitavad, ei ole nad õiged dünaamilise VH omad ega ka domineerivalt isodünaamilse omad. Samas puhtalt isodünaamilsele eheduses siiski konkurentsi ei paku.
      Ülalolevale ma paneks juurde mingit 5" midbassi kaks tk.
        • 2821
        toimib küll. nagu see: https://www.adam-audio.com/en/main-monitor/
          • 7723
          See Adam S6X pole päris sama moodi 3 valjukat sama kõrgete riba mängimas, seal on suuremad lintvaljukad keskribasse filtreeritud ja väike üksik mängib kõige kõrgemat otsa.
          Või sain mina valesti aru, kuidagi väga harjumatu on näha XT25SC90-04-d kesksageduse valjukana.
          • hipster
            • 04/2020
            • 111
            Oletame et on plaanis ehitada selline kõlar:
            Aga kõrgete osas võiks olla midagi huvitavamat, nt see kombo, mille välja pakkusin.
            Mõttel oleks jumet kui saaks esimest järku filtritega hakkama, umbes 2kHz-i ja 7kHzi lõigetega.
            Alumises osas siis:
            Speaker Impedance: 8 Ohm, Power rating: 200 W RMS, One of the most popular loudspeakers for electric bass applications, Ideal for all 3x 10", 4x 10" and 8x 10" speakers, Also suitable as a mid-range speaker in PA systems or 3-way bass speakers
            Läheb ennustamiseks, aga kui suur võiks kõlari võimsustaluvus sellisel juhul olla?
              • 7723
              Siis ikkagi 3 riba plaanis?
              Kuigi lingitud kõlarid on siiski kaheribalised, filter kuskil 1kHz juures.
              Võimsustaluvus on väga komandajärguline asi, olulisem on saavutatav piisav helirõhk, piisavalt väikse moonutuse juures. Nende valjukatega ei tule aga kuidagi kokku kõlarile 8 oomist nimitakistust, bassi otsa tuleks 4 ja kõrgetel üldse 1,3 oomi, SB acoustic-ul ei ole nende netilehe andmetel muid ringradiaatoreid kui 4 oomised.
              viimati muutis kasutaja moi; 25 April 2020, 11:18.
              • hipster
                • 04/2020
                • 111
                Kolmesed jah, nagu esimeses postis mainisin. Lindid tahavad kõrgelt lõikamist, seepärast 3 riba. Ring radiatoritega olen kunagi katsetanud, vene lintidega ka, seepärast see kombo ahvatlevana tundubki.
                Dünaamilise kesksageduse lisamine võib ka kõne alla tulla. Aga see kõik kokku pole konkreetne ehitusidee, tunnetuslik mõtteharjutus esialgu pigem.
                • martk
                  • 01/2013
                  • 1834
                  Audio-onud omavahel:
                  lindid vaja läbilõigata - uusehitus neil avamisel
                  Rääkige pärast 15. aastast foorumis osalemist inimkeeli, et ka kaaslugejad/mõtlejad ilma krüpteeringuta sellest tegelt lihtsast teemaarendusest tulevikus ja nüüd aru saaks.
                  Hipsteri unelm - bass mängib kõike ja kõrgsagedus mängib kõike, vaja vaid lõikesagedus ja 1. astme filter igaksjuhuks tekitada - ainult pole kumbagi reaalset toodet - ei bassikat ega kõrgsagedusvaljukat?!
                  Audio-onud parandage, kui eksin.
                    • 2821
                    ega tal jah juppe näpuvahel (veel) ei ole.
                    ta peaks kõigepealt sellega modelleerima: https://www.diyaudio.com/forums/soft...-designer.html
                    • MK
                      • 10/2003
                      • 1970
                      Esmalt postitatud moi poolt
                      Peaks olema satori seeria omasid ka 8 oomiseid.
                      Mis selle kahe - kolme ringradiaatori point on ? Eriti väikse flansiga xt25 mida ennast alla 4 kHz lõigata väga ei saa.
                      Lihtsam mingi suurem/võimekam kuppel 1 tk + mingi ribbon kui nii väga vaja on.
                        • 7723
                        Esmalt postitatud martk poolt
                        Millest selline sarkasm ja mõttetu sissejuhatus?
                        Tuli ju välja, et 3 riba ikka plaanis. Kui hästi ja mitte kõige odavamaid valjukaid valida, saab ka lint kesksagedustega hakkama aga seda ka nagu plaanis pole. Lint läheks ainult kõrgsageduseks, Kesksagedusse aga võtaks jah midagi sobivamat kui XT25SC90, ikka mingi päris kesksageduse valjuka. Võib ka kuppel olla kui bassi valjukas korralik on. Eminence Legend BP102-8 on ikka nagu kidra valjukas, ehk muusikainstrument, millel peab olema oma isiklik tämber ja spetsiifiline moonutus. Korralikus koduses kõlaris peaks valjukas ikka neutraalne olema, ilma isikliku arvamiseta sellest, mida ta mängib.
                          • 7723
                          Esmalt postitatud MK poolt
                          Satoris on 8 oomiseid aga mitte ringradiatoreid nagu Tekton Pendragon pildil. Võimalik, et vanasti oli, Pendragonitel juba vanust ka piisavalt.
                          • martk
                            • 01/2013
                            • 1834
                            Sarkasmi pole - on puht füüsikaline : Kirjutad et: olulisem on saavutatav piisav helirõhk, piisavalt väikse moonutuse juures. ..91dB (viimase jõudsid kustutada - häbi-häbi). Kõigist su kõlariteemadest kumab läbi, et sulle helirõhk on tegelt tagumise tähtsusega, kui jutt madala heli edastusest. Sinu sõna - piisav - on piisavalt laialivalguv.
                            Et mõttetu - see on sinu arusaam minu postitustest Andke hagu audio-onud - karantiin paneb mõtted liikuma
                              • 7723
                              Piisav helirõhk on igale inimesele individuaalne number, seda ei sa keegi teine ette kirjutada ja 91 dB-st seal kindlasti juttu ei olnud, parandatud sai üks trükiviga.
