Mõõtmised ja tajud
  • martk
    • 01/2013
    • 1834
    #286
    Vs: Mõõtmised ja tajud
    Herr Sonic, kas tajud ainult digiheli või meenub noorusest ka analoogi hääl? Küsin juhuks, kui mõni huviline tuleb vinüül kilekotis sulle koju kaableid kuulama.
    • Sonic
      • 02/2004
      • 1144
      #287
      Vinüül on igati teretulnud
      • OSX
        • 02/2007
        • 5594
        #288
        Esmalt postitatud moi poolt
        Ok, see asi on siis ka lahendatud.
        See asi toimib pea kõigi massinatega milles Mediateki MT8560 või MT8580 protsessorid kasutusel, mitte ainult OPPOga.
        • martk
          • 01/2013
          • 1834
          #289
          Miks insener ei saa olla "kuldkõrv2
          Q: Why is it, when discussing circuits in internet forums, that people with no technical background always seem to claim that they can hear so much better than someone with an electronics background?
          A: That's the "golden ears" strategy, a time-honored internet arguing technique used with limited success by those who are usually "technically challenged", i.e. "internet armchair engineers", who cannot produce supporting data to back up their side of the argument. These people tend to rely heavily on tenuous, unprovable concepts, such as "magic" and "luck"to describe circuits, rather than anything concrete, like mathematics, scope plots, or plain old reason and common-sense.
          The laws of "golden ears" are a bit complex. Here they are, at least as far as I have been able to ascertain:
          (1) "You are not allowed to make any mention of golden ears until you are losing an argument and have no way to save face."
          (2) "He who first proclaims to have golden ears is the only one in the argument who can truly have golden ears." The opponent, therefore, must, by the rules, have tin ears, since there can only be one golden-eared person per argument. Now, everyone else on the board may have golden ears, but only if they choose not to perform the test in question that may disprove the theory. These people may be brought up as often as possible, until that point where they actually perform said test and obtain results not in accordance with the original golden-eared proponent's position.
          (3) "Golden ears can only exist on a person who has no formal education in the subject matter." The minute a person receives an engineering degree, his ears automatically turn to tin, and he cannot be trusted with even the simplest test of tone or frequency response, no matter how long he or she has been in the field of interest.
          (4) "Once you have proclaimed golden-ear status, you can no longer answer any questions, nor put forth anything of a technical nature, because you may slip up and show that you really have no clue as to what you are talking about." At this point, your golden ears have become tarnished, and everyone will see the emperor has no clothes, so this situation should be avoided at all costs. Should this happen, you have no choice but to either slink away and hope nobody notices and soon forgets about you, or loudly proclaim victory in the vain hope that someone will believe you.
          • martinj
            Administraator
            • 11/2002
            • 8691
            #290
            Päris head seletused,tundub, et peab paika.
            • riksx
              • 329
              #291
              Selle võiks ära raamida: "The minute a person receives an engineering degree, his ears automatically turn to tin, and he cannot be trusted"
              • Sonic
                • 02/2004
                • 1144
                #292
                Esmalt postitatud riksx poolt
                Tõlge ka: "Minul, kui inimene saab inseneri kraadi, lülitub tema kõrvad automaatselt tina juurde ja talle ei saa usaldada."
                • martk
                  • 01/2013
                  • 1834
                  #293
                  OSX kirjutas:
                  Juhe peaks aga nii kvaliteetne olema et igasugused juhuslikud bosonid sinna ei uitaks.
                  Tõlkerobot väljutas:
                  However, the cord should be so high-quality that any random bosses will not get into it.
                  • OSX
                    • 02/2007
                    • 5594
                    #294
                    Kui huumoriga jätkata siis kellele kuulub selline mõtteavaldus - "Me võime kuulata kõike, mida mõõdame, kuid me ei saa mõõta kõike, mida kuuleme. Pane oma kõrvad oma juhendiks."?
                    • stosoorok
                      • 12/2003
                      • 762
                      #295
                      e: vist ikka mitte.
                      • GU50
                        • 11/2004
                        • 2139
                        #296
                        Pikalt on siin räägitud kaablitest, mis on ju omamoodi nabanöörid seadmete vahel, nendes pulseerib ju ELU ISE! Tänasele trenditeadlikule audiofiilile enam ei piisa, et juhe viib voolu punktist A punkti B, midagi olulist peab veel selle protsessiga liituma. Müsteerium "haldjad ja päkapikud kaablis, kes värvivad helisignaali" hakkab oma aega ära elama... Seega kindlasti avardab tajumisi elus kaabel, pole kaugel aeg, mil selline edumeelne elutehnoloogia jõuab ka audiosse.
                        • Sanches
                          • 02/2011
                          • 96
                          #297
                          Kes mida videos märkab, minule meeldiks sellist tüüpi pikendusjuhe, ainult meie standardil, ümarate aukudega. Pole kohanud meie kaubanduses.
                          • martinj
                            Administraator
                            • 11/2002
                            • 8691
                            #298
                            Esmalt postitatud Sanches poolt
                            Meie standardile seda teha ei saa, kuna kontaktid ümarad ja peab olema välistatud ainult ühe kontakti sissepanek.
                            • Sanches
                              • 02/2011
                              • 96
                              #299
                              miks ei saaks : http://www.motonet.ee/et/toode/38402...pesa-Euro-4-os
                              • Sonic
                                • 02/2004
                                • 1144
                                #300
                                Kahjuks pole ühtegi skeptikut siiani kohale saabunud, loodetavasti on takistuseks olnud külmad ilmad.
